Can The AB 9300-USBS Adapter be used with...
ian.smith7
Aug 2002
UK
145
Hi
Just Installed an AB 9300 USB adapter on a Win7 (32bit) laptop and all is working fine to SLC and MicroLogix PLCs.
Since we have some Mitsubishi PLCs (an A series and 2 FX-2n) I wondered if anyone had tried this adapter on Mitsubishi PLCs via GX Developer.
Is it compatible did, it work OK?
Ian
There is nothing special about the 9300-USB adapter. It is a standard USB to RS232 adapter. If your other branded PLCs use standard RS232 communications, it should work.
The only exceptions are devices like the old AB PIC boxes where a real physical serial port is required.
OK.
It looks like the only way to find out is to try it.
Ill give it a try tonight at work.
Cheers
ian
HELLO , Is there any problem using 9300-usbs with a windows XP service pack 3.I am not able to connect to the plc through this and 1747-CP3...
4,318
I have Windows 7 Pro and am trying to configure ABs 9300-USBS USB to RS232 adapter. I have done it in Windows XP but am having problems with Win 7...
2,291
Has anyone used a allen bradley 9300 USBS on windows 7 pro 32 bit? I know it works well with XP pro but I'm not really seeing any support from AB...
3,032
Gents, I've a brand new 9300-USBS USB to serial converter, but the drivers supplied on the CD or on the site of Rockwell won't work. I've a Dell...
26,801
Does anyone know where I can get a free download for the 9300-usbs adapter I have seem to misplace the device driver CD that came with the...
7,244
