A-B analog outputy card trouble
bsprowls
Sep 2005
Ottawa, ILL
35
I have a PLC5/40E with 1771-IFE analog output cards. Once in a while the card will "freeze" and a point will only put out 4ma. The PID will appear to be working, there is no fault indication exterinally at all.Register N14:6 is the actual control variable from the PID instruction, and it follows the manual control command, but the point will put out just 4 ma. I have to toggle the PLC5 with the key to get the card working again. The BTW instruction to that card does set its .ERR bit. My questions: what can cause a card to fault like this, and, how can I reset the BTW without toggling the whole PLC5?
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
39
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
130
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
143
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,213
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
289
