A-B CCW Timer Logic
motosman1
Nov 2015
TEXAS
17
I still have to preface this with "I am a newbie". Fumbling my way through ladder logic in Micro820 using CCW software. I need to send a 24vdc signal to a water softener control valve, and hold that signal for one minute before removing it. Not sure if I need a one-shot (which will be a Pulse Rising Edge Coil in CCW, from my understanding) with timer or a Set Coil/Reset Coil. I've been looking for some sample rungs but no CCW samples seem to elude me. Thanks!
I am not very familiar with CCW, but have done extensive work with RSLogix Ladder Logic. I would recommended using a timer. In RSLogix you could use the .TT bit from a timer with a Preset time of 1-minute. Looks like the CCW timers do not have the .TT bit but you could accomplish something similar with some pretty basic logic. Here's a video on using TON timers in CCW: https://www.youtube.com/watch?v=YFdo8vmZ7Yk&index=30&list=PLoZeeIwna8C1JCEbQ9Z9zAXOmmLetgtMn
Also, if you have further questions on PLC programming in RSLogix or Ladder Logic check out my recent blog post on A-B Ladder Logic programming: http://www.myplctraining.com/beginners-plc-overview-part-4-of-4-plc-ladder-logic/
The attached shows how to create a TT bit. The last line says CYCLE_TIMER_DN but it should read CYCLE_TIMER_TT.
The timer's in CCW operate a little different then RSLogix, but you would still probably want to use a timer.
So, is this going to be everytime a start(bit) becomes true the control valve will be energized for 1 minute?
I think something like this might be what you are looking for.
I confess, I always have a little frustration trying to accomplish tasks in CCW that are simple in Studio 5000. My latest task is with timers...
480
Hello, I am new to PLC programming. I just got an AB Micro810 with the CCW software. I am trying to create a timer that has an on time of 100ms...
1,645
Hi, I've been lurking for about a month now and via the search, I've been able to string together a basic micro820/PV800 project. I've got a...
3,074
Hello, I am new on a forum. I have some problem with programming of PLC Micro850 which i can't figure with use of help in Connected Components...
1,575
G'day guys, Just wondering is anyone could help me out with this one, i've done some plc programming before but never on CCW. Trying to knock up...
2,773
