Ironically, I have never done any function block programming in Logix5000 itself, but I have to draw out a program for it.
My question is, what do you use to do something only if true?
I.e. I want to set a value to true if another value is >14, but also it should be set to false if that value is <10. If I simply use a greater than block, my value will get set to false as soon as it drops below 14. How can this be accomplished?
Attached is the equivalent in ladder logic.
Thanks for your help!
