A&B/TSX and howto send sms
Loordi100n
Aug 2006
irl
20
Hi all..
Iam using A&B (slc500) and/or TSX (micro/premium) and need to send sms when an alarm is triggered.
1. Can it be done directly from I/O (i.e I1.0 -> can memory bit, done with programming, surely). But without any PC/SCADA/HMI/OPC/etc. Kinda "hardwired" way..???
2. If HMI/SCADA is in use???
Thanks in advance...heil PLC :)
You can quite easily send SMS messages directly from the PLC.
Connect a GSM modem to CH0 of the SLC (i'm assuming you're using a 5/03 or higher) - use the AWT command within Logix500 to send the necessary AT commands to the modem as ascii characters (i.e. AT+CMGS etc) via STRING registers.
If you search the forum, you'll find sample code (i've posted a bit myself...)
Hope this helps! (y)
Rob.
Hi all.. Iam using A&B (slc500) and/or TSX (micro/premium) and need to send sms when an alarm is triggered. 1. Can it be done directly...
1,618
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
65
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
155
Hello Dear Experts I have to read 2 words (%MW300 / %MW301) in a M221 plc (TM221ME16R/G) which have a embedded ethernet port. the reader plc...
748
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
374
