A hitch with 1395 drive
rejoe.koshy
Dec 2011
kolkata
195
Hi guys,
I am facing a peculiar problem a 1395 dc drive, make- alllen bradely.
When I issue a jog command to the drive via PLC it works fine , but when I impart a run reference to the drive it fails to produce any output.The drive receives the reference from the PLC but fails to produce an output voltage inspite of the fact that its output contactor is energized.
What could be the cause?
pls help guys!!
take care
yes ,all the permissives are made. The plc issues the run command to the drive along with the speed reference , but no output voltage is recorded.
I had an issue similar to this with a 1395 a while ago, it eventually stopped altogether (every time we would get to the machine it would jog then start back up and run for a few hours). The problem ended up being a relay that was going and finally just failed completely. I don't remember if it was internal to the drive or external but I would start there.
I am having to recreate a PLC5/40 program from a paper copy. Unfortunately there is no documentation on how to setup the 1395 drives with RIO...
1,553
I have a 500 hp. Drive that has a field loss fault. changed drives, no help. Changed motor, still has field loss fault. put a resistive load on...
4,147
Hi there: I'm hoping someone out there is still familiar enough with the Allen Bradley 1395 drives to help me out. I've been trouble shooting...
3,589
Platform SLC 5/04- 1747-ASB. Has anyone ever attempted to "monitor Universal RIO communications rate" via ladder logic for the above listed...
1,423
hi guys, I need help to configure 1395 dc drive with plc 5.How do I link the drive parameters to inputs/ ouputs of plc.Pls help!!
1,992
