configuration of 1395 drive
hi guys,
I need help to configure 1395 dc drive with plc 5.How do I link the drive parameters to inputs/ ouputs of plc.Pls help!!
First you will have to decide what type of integration you are going to use.
1395 has been and still is a workhorse within DC motoring applications, however,it is Silver Series listed and the user integration options are limited to
I/O (using the Discrete Adapter/Discrete Reference options), RemoteIO/DH+ communications (using the Node Adapter or Multi Communication option)and ControlNet (using the ControlNet Adapter option).
For options visit:
http://literature.rockwellautomation.com/idc/groups/literature/documents/pa/1395-pa000_-en-p.pdf
Unless you have a ControlNet PLC5 the last option is not feasible.
If the PLC5 has RemoteIO/DH+ capabilities install the Node Adapter/Multi Communication option and Block Transfer/MSG the Command/Status information.
If I/O is the only option, install the Discrete Adapter/Digital Reference option and use hard wired I/O between the CPU and the 1395.
User Manual at:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1395-um003_-en-p.pdf
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
51
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
61
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
99
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
