A little question about S7 IEC timers.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,325
Siemens product sheets for their CPUs state that the number of IEC timers are "unlimited".
But I thought that the number of IEC timers would be limited by the max number of DBs for the particular CPU, as each IEC timer must have a DB associated with it.
So, which is correct:
1. The number of IEC timers on an S7 CPU is unlimited.
2. The number of IEC timers on an S7 CPU is limited by the number of available DBs.
Thanx
Hi Jesper :eek:)
If you use the IEC Timer as Multi Instance, you have to declare the Timers in the Declaration-area, then they don't need a DB, the working-area of the Timers will then be in the DB that you assign for your FB, this will only be possible in FB's
Hilsen Steffen
Or you can have a lot of timers in one DB. I tend to use one DB for timers and a second for counters. You add the timer to the DB then you can reference that as you add a timer to your program.
Hi, I need to compress 3000 ft^3 of a syngas(synthetic gas) made up mostly of hydrogen, carbon dioxide and a little methane. I cannot seem to...
2,525
I used the recipe system in WInCC Flexible. I made a CSV by using export I make changes in the csv I used import When I do...
3,969
I need to regulate something in this way: How is this in math and how van I write it in stl ? Thanks in Forward.
3,546
I always trouble to make rotary encoder with H21A1 or H21A3, that optocoupler always shutdown which i didn't know. how to make a good rotary...
2,099
I’m currently a student of Communication systems, majoring Multimedia and Design in The Netherlands. My first education was Technical Production...
2,642
