A Noob question…24v
Totally sensible question.
You can get into trouble with separate power supplies or long distances, but wiring a solid-state sourcing output to a solid-state sinking input is a totally standard way of testing I/O and throughput timing.
but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
No reason to laugh... some PLC manufacturers, like Rockwell, can have modules with different voltages, so you need to look out for that. So it's not a straightforward question, but in this instance you're correct in your conclusion.
Check this part for an example.
https://literature.rockwellautomation.com/idc/groups/literature/documents/in/5069-in001_-en-p.pdf
Just verify max leakage current from the output module and compare to the OFF current/voltage max on the input module. If a problem a shunt resistor may be needed.
Let us know how it goes.
I am working on measuring a 5V pulse duration by having it gate a 24V 40kHz Pulse Train Output from an output of the PLC to the High-Speed Counter on an 40kHz 24V input of the same PLC.
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
962
Hello. I'm wanting to use a boolean value associated with turning an output on to control the visibility of an image. The visibility option in...
2,145
Hello, I did a programming using MOVE block. However, whenever i press input. The MOVE block does not read the value assigned to transfer. Instead...
2,639
Hi, I have tried everything but still having no luck. This will be a easy solution I just know it. Ok I want to be able to set off an output...
1,784
Gents, So I am reading through the manual for this drive, and it sounds to me like I can only use this drive in combination with a logix...
1,335
