I know this has come up before. I'm not asking for assistance. Well ok, if you have something else to add you are more then welcome
Here is my setup.
I have 9 machines all pretty much the same. Give or take an IO card.
SLC5/04 on a 10 Slot Rack.
First 5 slots are IB16's or OB16's
Last 4 slots are OW16's, with a free spot or two.
All machines ran fine for months, then 4 of them started getting this error. After searching this forum, and goggling.
I move the OW16 from slot 8 to slot 7.
Problem went away.
This week another machine started getting the same error.
I did the same, fortunately the machine builder didn't use slot 7. I move the OW16 from slot 8 to slot 7.
Problem went away.
Could this be a problem with the 10 slot rack. Slot 8's data path is real close to the relays on the OW16.
Oh and I should mention, there is no real load on relays 7 and 8 (to my understanding are directly beside the data path).
On these relays I have Numatics Soleniods. Could it be an issue with this. dunno.
I didn't get into changing output connections on the OW16. I guess I just got lucky.
Adam
Here is my setup.
Problem went away.
Problem went away.
Adam
