A sensor for a conveyor belt
Gromit
Jun 2006
119
Hello,
Could you please recommend a contactless sensor for detecting the tearing of a rubber conveyor belt?
May be some of the Siemens BERO sensors?
Are you looking for a complete tear, or even it starting to tear? Also, even though it is rubber, does it have metal embedded in it?
George
If there is a measureable difference between motor loading with a torn belt compared to the drag of a good belt, you could set up an underload detector (actually an undercurrent detector) on the motor leads. ABB and Symcom make these for motors on mag starters. If the motor is powered by an inverter, some inverters have underload detection faults or one of the output relays can be set up as a current level detector. On the drives I am most familiar with (ABB) you can set up delay time on underload as well so you don't tend to get nuisance tripping.
In my experience, you have to be very careful about setting up the level detection to avoid nuisance faulting from routine operating conditions.
An expensive option could be a measuring light screen such as Banners A_gage mini arrays however you would need room to place the reciever and emitter this option could work if your belt is moving slow enough
i'm looking linear metal detecting sensor cross conveyor. anyone have used any type of this sensor? conveyor belt is 10" width.
3,275
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
84
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
118
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
220
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
174
