sheryl86_ann
Hello^_^ Does anyone knows how to connect a 3 pin nanaboshi, 15A each (which is 3 sets) from 3 heaters(600W each) into a single nanaboshi with about 30-50A but 8 pins? Will sodering the pins work in a high heat considering these will move forward & backward?
Or, will it be possible if without using this single nanaboshi (30-50A),only the three sets of 15A, (3 pins each) nanaboshi will be connected directly into terminal blocks but i only need line 1 & 2 (2 pins)for this scenario. The 2 pins will be connected into the solid state relay going to temperature controller.. Is it possible?
Thanks Gentlemen!
Thanks Gentlemen!
