A very rugged PLC and HMI
reply
Mr. Lucas,
With regards to your question on the manner of testing.
Standard mounting was used. No vibration dampeners were used during the testing that I had mentioned previously.
Hope this helps.
God Bless,
Stephen Luft
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
110
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
95
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
136
Hi i would like to ask! Im using Omron CP1E PLC May i know how to use one input to trigger two outputs alternatively? Meaning press X0 on, Y0...
403
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
433
