A2n cpu run LED flashes
prateek1190
May 2012
Nasik
hi friends,
I'm using Mitsubishi A2N CPU of which run LED flashes continuously...
I've made PLC diagnostics and it shows battery error..
I've replaced the battery.. but again it is showing the same error...
please help me out guys...
thanx...
Hi all I need your valuable assistance urgently! I am new in Mitsubishi plcs environment and I used GX Developer to read a plc with A2N(s1)...
2,291
Hi, I am facing problem to edit Mitsubishi A2n PLC program (RAM) having link parameters set. The station is working as master station with three...
4,779
Hi, I have three Mitsubishi A2nP21 PLC connected with each other through optic fiber, configured as one master and two local stations...
1,766
Hi I am new to Mitsubishi PLC. I need to write a program for A2N PLC to display on a TV screen. The display module is AD57. Could you...
3,449
Hi I have got two sets of Mitsubishi PLC. The units are A2N CPU, AD61 AY42, AD57 and AX42. I need to know what each unit does. If you can...
3,334
