A2ncpu Run led flashing and error led on
Jul 2010
India
We are having a printing machine with this A2ncpu in use. Two days ago, sometimes when we inch the machine, the error led comes on and the run led flashes. on resetting the fault was getting rectified and the machine would work. AS ON TODAY,WHEN THE MACHINE IS POWERED UP, THIS ERROR LED COMES ON AND THE RUN LED FLASHES.
could the battery be the cause of this problem . how am i supposed to go about to detect the fault.
Hi all, I'm needing to program a very old A series PLC where the CPU is a A2NCPU. When I try and select the PLC type in GX Developer I do not get...
2,684
Hello! I have a problem with our A2NCPU it does not communicate to PC anymore, when I about to upload the medoc program by using SC-05 cable...
4,232
We tried to connect a Mitsubishi A2NCPU to an OP170B from Siemens with the RS422 serial interface, but without succes. Here you can see how we...
5,115
Can anyone help me with a documentation about counter module AD61 (MELSEC MEDOC A2NCPU) or other documentation about A2NCPU ? Regards, Vlad...
4,963
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
22
