What version of GX developer to program a A2NCPU
Tjkeets90
Mar 2018
England
39
Hi all,
I'm needing to program a very old A series PLC where the CPU is a A2NCPU.
When I try and select the PLC type in GX Developer I do not get this CPU in the drop down just the A2N(S1).
I'm using version 8.116W.
Can anyone tell me if it is even possible to program this kind of CPU with GX Developer and if so what version or will I need Medoc?
Thanks,
Tom
Can you select just A?
In Works2 I can select A2N so I would think GX would also let you select it
Just connect to the plc and it will tell you what it thinks it is connected to.
Probably the A2N(s)
It won't make much difference.
Program away.
Probably the A2N(s)
Program away.
+1
Before Works came out the only option was Developer so it has to support it, i'm thinking like Ronnie and just connect
I have GX Dev v8.25B and and it does not support the A2N series CPU's. It only supports the FX series.
I have GX Works for that.
There were two version of GX Developer (3 if you count the 1000W version) one was full and supported A, Q and FX and they also had a cheaper FX only version
GXDEV V8.5 supports A2N(S) so it should support all A series, You say you are getting another PLC, why not upgrade to the Q series or newer, the A series is long past it's support date.
GXWorks comes bundled with GXDeveloper and will run a GX Developer session when the A series is selected (it is called compatible mode and will only do ladder).
Anyone know why D408 is 0.000, when I want it to be 25.000? There is a 1 dataword gap after D408 (ie D408 is not used), so that shouldn't be the...
2,330
HAs anyone converted the melsec files to GX Developer files from inside GX Developer? GX has an import function but when I use it I get an A/FX...
3,950
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
