AB 1400 Micrologix IP Port
bearsgone
Jun 2010
chico
49
Hello
I am wondering if somebody had experience with setting up AB Micrologix PLC such as 1400 or similar to respond on different port such as 192.168.1.1:81?
Not sure if it is even possible?
Thanks for any help
I've just put a router on the network and done port forwarding to get the same effect. I've been the using the 1400 since it came out and never run across anything to change tcp ports. I like to use the Zyxel 2+ to do this kind of forwarding and firewalling - its got a very easy-to-understand web gui and has been very reliable in my panels.
Thanks for response
Some people mentioned that having PLC open to internet can do like a DOS attack to PLC. I was thinking about setting up VPN to avoid that situation.
Is there any other way to prevent anybody from the internet getting to PLC without using VPN?
I can't think of any reason you would ever permanently connect your PLC network to a broadband (Internet) connection except to connect a VPN: the VPN would allow you remote access to your PLC.
But to answer your question, any good quality firewall would insulate your PLC from the Internet - the VPN is your 'hole' through the firewall to allow you and only you from the WAN through the firewall back into the LAN.
I frequently connect a firewall during development so I can have Internet access (get prior projects, read literature, download updates, ...), then shutdown the ports on the firewall when I'm done. Or only leave the VPN on when I'm done. Like I said in the earlier post, I'm partial to the Zyxel Zywall 2+ since they have every feature I've ever needed, are cost effective and have proven to be reliable in my panels. But as far as firewall brands go, I'm sure 10 engineers would give you 10 different answers.
I also use the firewall to insulate my control traffic from my HMI traffic. For example, I put all the PLC's on the 'LAN', all the HMI's on the 'DMZ' and the Internet on the 'WAN' ports. Then I know that the providing Internet access to the HMI (WAN to DMZ) can in no way affect the traffic on the PLC (LAN).
Hello Everybody. Can some body let me know whether a Servo drive can be controlled through Ethernet or devicenet using Micrologix 1400 PLC? if yes...
2,950
Hi.. I am using Micrologix 1400 PLC & C600 HMI. I want to do the communication between them by DH-485 via RS485 port.( As distance between them...
4,308
We are using the Micrologix 1400 to control Solar Panels and we need remote access. Does anyone know what ports to forward on the router? Thanks.
21
20,150
Morning All, Can i use the Micrologix 1400 Builtin ethernet port to connect to a bradley ethernet network to give status back to a SCADA system...
4,659
63
