AB 1746-NO4I 0-20/4-20mA problem
allistondc
Jul 2013
Marikina City
I've experiencing problems regarding the decimal equivalent to mA reading of each channel.
Based on 1746 NO4I manual, the equivalents are:
1. Decimal: 6242-31208 = Current: 4-20 mA
2. Decimal: 0-31208 = Current: 0-20 mA
I've tested both options using 5 point test but it seems that the mA output of the module is not linear with the decimal equivalent. Only 4mA at 6242 decimal is the one that is close. The max decimal 31208 is at 17mA Reading directly measured from the channel. Ive tried to replace the modules but still no luck. Am i missing some configurations like programming beace the advance config of the module is disabled.
What is the VOLTAGE output at the terminals when you are measuring 17mA?
My first thought is that your load resistance is too low, and the module can't source enough current.
Can you compare to another module or output channel?
Dear Friends, Need your expert opinion. We have SLC500 and installed Analog Output module is 1746-NO4I. Scaling and PID configuration is 0~16383...
1,951
Today we started commissioning an SLC 5/04 system that a customer purchased used. The entire system presumably was fully operational at the...
3,788
Greetings; We have a flow meter measuring our Process Water flow, and it sends a 4-20 mA signal to a SLC 5/05 through a 1746-NI8. The head...
2,988
Hi, I'm in the field. Long story short... their original devices have failed, and they're not getting the required temperature (analog) data. I...
2,040
I have 2 identical systems, 1 beside me and the other 1000 miles away on site. During commisioning the NO4I started playing up, it gave just 4 VDC...
2,488
