AB 1766L32BXB PLC how to connect outputs.
mbreddy
Nov 2014
bangalore
22
Hi all,
I am new to PLC and recently started learning PLC programming.
Started with simple program wiht IN0 and OUT0.I wrote code to energize OUT0 when there is voltage in IN0 and dumpled into the PLC. I can see the change in IO for OUT0 status in PLC lcd indicators but when i am trying to measure OUT0 with voltmeter , it is not showing anything but i can measure IN0 voltage.
I didnt connect anything to OUT0 pin.simply measuring voltage.
Now could you pls let me know if i have to connect anything for OUT0 to measure voltage or did i miss anyghing.
thanks,
Hi mbreddy,
welcome to the forum.
on the ML1400, OUT0 is an isolated relay output, so requires a 24 V voltage supply onto terminal DC0, which supplies that output only.
OUT1 is similar in that it has a Voltage terminal DC1, whereas other digital outputs are grouped as a block.
Try connecting the 24V to DC0 and let us know how you get on?
In the box with the processor should be a wiring card, giving you the terminal layouts
Hi, I have added digital output expansion module(1762-ob32t) to the PLC and able to program the output but when i try to measure the voltage,i am...
2,982
Hi All, Could you please let me know if there is a way to connect analog devices for the PLC AB 1766L32BXB? Thanks, Bhaskar
2,251
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
141
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
74
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
90
