AB 1770-KFD module
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi. I have a question on an interface lead for a 1770-KFD module. (Allen Bradley 232 to devicenet interface module) I just purchased a second hand one on EBay and it did not come with a standard null modem cable. The cable supplied where it normally fits into my serial port has a flat plastic extension about 30 mm long with 10 contacts on one side of it. The only writing that makes any sense is PC327. Any one have any idea what this cable is used for. Regards Alan Case
Weird one. I don't think it's an A-B cable, probably something the user was interfacing to a nonstandard RS232 port.
I use 1747-CP3 and 1756-CP3 cables interchangeably with the 1770-KFD's serial cable often. I'm not sure they're identical, but they always work for me.
The real KFD cable pinout is in the installation instructions:
http://www.ab.com/manuals/cn/177056.pdf
(p.s. I use a USB-RS232 converter with the KFD, and I need to use that cable or a jumper cable rigged the same between the converter and the KFD.)
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,472
I am new to plc and DeviceNet.In the 1749 devicenet scanner module datasheet, I read that I need a 1744 KFD to connect the DeviceNet scanner with...
952
Evening all, I'm hoping someone can point me in the right direction with this issue where I cannot set up a 1770-KFD driver in RSLinx without...
6,284
Any reason why the driver does not show up when I select the devicenet driver selection in version 2.57 it shows up and in version 2.58 and 2.59...
3,732
Hello, Please, I need help, I have a 1747 SDN which set at 125 Kb/s Baud rate. I want to configure also the 1770 KFD et 125 Kb/s but, the 1770...
3,295
