AB 1771-IIC TC card info needed.
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
I saw an ad for 1771-IIC THERMOCOUPLE INPUT EXPANDER MODULEWITH SWING ARM on ebay (not the most credible source), but I was trying to see if it is compatible with the plc2/17.
I've been surfing a bit using the google search engine, but haven't even found 1 hit for this card.
Anyone familiar with this?
Here's a link to the item:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1750030843#DESC
T.I.A.
Russ
I wouldn't swear to it but that doesn't sound like a correct part number.
The "C" at the end means the module shipped without a swingarm. That means that the part number is a 1771-II. And that just doesn't look right.
I looked all over the A-B Manuals Online section and saw no mention whatsoever of any module like that.
Ask the eBay seller for a better picture and double-check that part number.
Good Luck!!
OG
It might be a 1771-IY, the expansion module for an old 1771-IX thermocouple input module. You need an -IX module (it's two slots wide !) before you can start stacking up to eight -IY modules onto it.
Such modules work fine with PLC-2 controllers; you end up with difficulty trying to use them with newer controllers or I/O adapters. There are a couple of Knowbase documents about the IX module and how it compares to the newer IXE and N-series input modules. There are also a number of newer modules that use components called "TIC Chips" which interfere with the 1771-IX.
Even at e-bay prices, this probably isn't a bargain.
Then OG is right about the "C" just referring to the wiring arm.
This module won't do anything without a 1771-IX to act as the A/D base.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
377
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
596
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
906
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
982
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,056
