AB 1771-QRC Rev A Series C Manual
controlconcepts
Oct 2008
boston
300
Hello All,
I have a 1771-QRC Rev A Series C Module that I need manual for.
On the card it says (See Users Manual Ref # 1771-6.5.20)
I have searched and searched and the only results I found was a reference in a 1771-CFM Manual that referenced the QRC for replacement. On page 65 of http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1771-um099_-en-p.pdf
If any one can dig back into the good old days [Probably a hard paper copy you could hold and markup] and can point me in the right direction it would be greatly appreciated.
Thanks in advance.
Matthew
Last rev of this manual was published in 1990 and as you can imagine it's paper only.
I actually located someone who has a paper copy but no way to scan whole thing.
If you can tell me exactly what you need, I may be able to scan few pages.
Wow!! Thank you so very much Contr_Conn. I was just taking a shot at it on here not thinking I would not get anything as to how old it was. All I really need is the module setup as to BTW and BTR. Again Thank you for all of your efforts it is really amazing. I just hope that some day I can have as much knowledge and resources as someone like you and other members to give back as much as I have gotten from here.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
373
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
596
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
905
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
981
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,056
