AB 1784-U2DHP Cable
bigdan5428
Nov 2010
Evansville, IN
I have used this cable many times before with no issues but after using it on another computer I can no longer get it to work with mine. I have checked all my device manager settings and they match the ones in RSLinx. It is recognized by windows and sets up the proper COM port (5) everytime I plug it in. RSLinx says that I have a "Port Conflict". I have had this problem in the past, normally I just stop the driver and restart and it works fine. I've tried to change COM port #'s, still with no luck. I consistantly have a port conflict. Has anyone else had this issue? or any ideas?
Yes all the time (but I do test a lot of cables)
1) Delete the driver in RSLinx (U2DHP)
2) In your device manager (with the cable plugged in) right click and click un-install
3) Once its done remove the cable and reboot your PC
4) start over... once the driver reloads note the COM port
5) remake the U2DHP driver in RSLinx
Should work just fine
I have tried this several times with no luck. The cable has the USB and power lights on when plugged into the laptop. But when I try to start the driver it just tells me it cannot start the device. The device driver then says "running" with a "port conflict".
Then try this...
4a) change the port number to another number
5) remake the U2DHP driver in RSLinx with the new number
If this does not work then you are not following the steps.... just did it today
I need a new 1784-u2dhp, and I am getting quoted $5000 CAD for a replacement communication adapter, which is as close to highway robbery as it...
3,167
hey guys. having some problems with my driver to connect to the SLC 5/04. I can configure it in rs linx, but when I go into rs500 to download the...
1,409
I have a 1784-U2DHP adaptor and have been trying to test it using linx. It lights the pwr led and the other 2 flash on when plugged in. Is there a...
2,122
I need one of these adaptors. I see there is an alternative one also available for less money that uses the Eth I/P driver? - anyone use it are...
1,051
Hello Friends; Good day. I have RSLINK 2.52 i have also 1784-U2DHP. But in the RSLINK configuring driver there is no 1784 U2DHP shown in the...
2,129
