AB 1790D "Protected" outputs
DairyBoy
Jun 2007
UK
393
Hello All. The digital outputs of the 1790D range of remote i/o devices from AB are described as "protected", but that's all; just a description. No one at R.A. has a clue regarding the permitted duration of a short circuit on an output and the pdfs just show a box labelled "protected output device". Does anyone here have inside knowledge or know of a pdf that gives this information? Thanks.
I believe that this is referring to the following:
To comply with the CE Low Voltage Directive (LVD), the DeviceNet network and outputs must be powered from a source compliant with Safety Extra Low Voltage (SELV) or Protected Extra Low Voltage (PELV). To comply with UL restrictions, the DeviceNet network must be powered from a source compliant with Class 2 or Limited Voltage/Current.
https://en.wikipedia.org/wiki/Extra-low_voltage
Hope this helps,
Garry
http://www.accautomation.ca
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
83
Pls anyone help me out to crack the Codesys lib File pls share password for the if any application to crack or any master key for Codesys library...
805
I have a password protected Siemens ET200SP PLC, with 'Permit access with PUT/GET communication from remote partner' option disabled. Is there...
455
Hello everyone, I'm working with an old ACM3710 device and I'm encountering an issue with the data frames I'm sending over an RS232 connection...
693
I have a SC9-LS24-3 surge protection solenoid cable from automation direct...
1,365
