AB 5/03 RS232 comms
jed
Jul 2006
Leeds
22
I am replacing a SATTCON PLC with an Allen Bradley 5/03 system which needs to connect to a PACSNET radio telemetry system. So how do I program the PLC so that the PACSNET can access relevant data to send/receive via the RS232 port (Channel 0). Is there a special data area used for the port?
Can anyone help?
Are you trying to figure out where to configure the serial port on the SLC 5/03? If so you'll need RSlogix 500: Controller / Channel Configuration / Chan. 0 - System.
There is no 'special data area' for the serial port. Once a connection is established to the SLC, all data should be available for polling from your SCADA system. I don't know anything about PACSNET or it's compatability with Allen Bradley PLC's. Maybe someone else has some experience with this combination?
Hello, I man trying to use a redlion DA10 converter to read data from a Bronkhorst mini cori flow meter over rs232. I cant seem to get the...
1,547
I have camera software which uses a keyboard to navigate, zoom move ect through serial. I want to be able to replace the keyboard for a PLC so I...
1,258
Hi guys Just wondering if anyone has succesfully read barcode data from these barcode scanners to a plc via rs232 or rs485? If so do you guys have...
1,466
I am having trouble with communication between my micrologix 1000 and my magelis HMIGTO5310 touchscreen i have added the allen bradley df1 driver...
1,487
So i have this application where I have to read/write from/to the serial port. Write has worked fine so far, but it is reading that I have issues...
1,875
