AB 5000 Citect Tag Syntax help needed
robbo
Nov 2005
Australia
85
Hi guys,
I have a small problem reading tags from a 5000 plc into Citect.
I can read tags from the top level ok, but need to know the syntax for nested level tags.
Any help would be great.
The tag I am trying to read is the 3rd level down, and has the value of 400 in it. Next shown is the Citect Address I am using - used the 3 names of the tag seperated by a "."
Managed to get this running - needed to be in Braces
format_data{0}.wait_pick_pos
Thanks again for your help!!!
(cant edit previous post sorry)
Hello everyone, Please provide assistance with setting up communications between Citect V7.5 SP1 P29 and Rockwell Studio 5000 Emulator, all...
2,044
Hi All, I am working on a project which uses compactlogix PLC and Citect SCADA. I don't have physical PLC at the moment. Need to test tag...
5,628
Can I use the Citect ABRSLinx driver for ethernet comms to Logix 5000 processor. If so what do I need to add to the Citect I/O device address to...
1,967
Hi All, Am currently working on a CompactLogix => Citect application and was would appreciate some discussion on alarming between the 2 systems...
2,079
Hey guys, I need help about communication between vijeo citct and rslogix 5000. I tried ABCLX driver but I didn't succeed. Would you send me...
2,029
