AB alarm programming HELP
kam
Nov 2011
Aurangabad
Hi all,
I am using AB ML1200 PLC and Renu 4057 HMI. I want to flash a message, on HMI, which indicates the on going process. And also want to display a message in alarm screen.
Please help to sort out the problem.
You can mail me on [email protected]
Kam,
What is the problem? What message do you wish to display that indicates the "on-going process"? What does the alarm message warn about? What action do you want to take when the alarm shows?
Now back to the beginning: What is the programming problem for your AB MicroLogix 1200 PLC?
Hi Lancie,
Lets go with an ex.
Suppose I want to Flash a message "Down Proxi On" when Down Proximity on at Field. I have set B3:5/0 bit when Proxi on, and Tag this address to Message "Down Proxi On".
Now I want to Flash this message on Renu Make HMI - FP4057.
Can you please tell me how to flash that message?
Kam,
The 151 megabyte program is a little too large to download for casual help.
The datasheet says for Alarms:
"Real time and historical Alarms can be defined in FlexiPanels. User-friendly Alarm object can be defined on the display. Alarms can be real time or historical. Keys can be assigned to acknowledge Alarm, view, and scroll."
I am sure that you will be glad to know that these Alarm Objects are user-friendly! Keep plugging on.
I'm looking for someone who is more experienced than to bail me out of this mental thought experiment. I am moving away from programmed alarming...
981
Hi guys, I am new with PLC programming so I want your lights.. We suppose to install a flowmeter( with analog current output 4-20mA), after an...
2,039
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
73
161
