AB ASCII Programming
roxtech
Mar 2008
Township Lahore
198
Hi Dears,
we are using Micro logix 1400 with modbus RS485. Now according to modbus we read 40001 Holding address in plc form a indicator. which is working fine. My question is How can we add one more indicator in plc which have only stander RS232C signel on ASCII. I donot under stand how we configer it in PLC programming. For example it want to read weight data from weighing indicator.<NET>? first of all I set ch 2 to ASCII.
My parameter is.
Driver ASCII.
BAUD 9600.
Parity None.
Stop Bit 1.
Data Bit 8.
How can I read data From indicator.
Please give me example code.
in Modbus we use MSG instruction and fill up setup parameter then its work ok.
Hello everybody. I am currently trying to send ZPL commands to a Zebra zt410 from a compactlogix L30ER with v30 studio 5000. I am connected to the...
1,115
I am trying to build an inventory management system that receives part numbers(Format, 123-45:67) from a bar code scanner and uses Allen...
1,505
HI, i am having trouble trying to differentiate between 2 strings using just integers, so i need to do a string compare and use the letters to...
3,074
Hi all- first timer here. I am a process control tech assigned a new to me task. Since i am not a true programmer am having trouble with the...
2,134
Hello everyone I am completely new to Ascii and I wanted to know if anyone has any idea how to get started, maybe some online tutorials or...
1,908
