AB compact logix plc ,L27ERM,1734-asci module ,
dineshdhav
Sep 2017
i have read scanner data to plc via asci module
i have some errors on that
eg. scanner data is = 26891876A190
but i am getting some time $7F$7F$7F76A190
it is automattically corrected by after 5-10 scanes
pls any one help to troubleshoot this
thanks advance
Is it possible to get the LED Status Lights out of the code? I will use the GSV Block with the 'Module' Class and 'LedStatus' for the CPU. I am...
589
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,038
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,957
Hi I'm currently doing a college course in robotics and automation and a question we were asked was. A software application used by production...
3,660
is there a way to open a compact logix plc program and then compare that to the program that is actually running in the plc Thanks
1,076
