AB Compact Logix to Serial
M.W
Oct 2009
West Yorkshire
21
I am looking at a way to communicate with a serial device from my compact logix over ethernet.
I have 4 devices, normally accept a a serial communications, that require a single value to be changed from the HMI, which I want to set through the PLC for a time and then reset.
Has Anyone any experience of writing the messages and reliable hardware for this application.
I was wondering if anyone knew of a card either Allen Bradley or an after market that allows a compact logix to communicate over serial using...
1,706
hi guys, I am having a problem regarding the communication between a micrologix 1100 & compact logix using the serial port.I have configured a...
6,198
HI there, I need that an RTU (DF1 Master) polls some data from a Compat Logix PLC (DF1 Slave) serially. I don't seem to find an application note...
2,220
Dear All, communication between compact logix 1769-L31 and Indusoft 6.1 +sp4 on serial protocol is possible? If possible then which driver to...
4,389
Hi All I am using Compact Logix L35 E processor's serial port as a Modbus Master by using Rockwell's provided drivers for Modbus. I was...
5,463
