AB Control logic plc fix 32 scada
To connect to the serial port of the control logix you can use
the ABH driver available from GE. Or use RSLinx,(then the ABR driver) a version other then
lite, (OEM,PRO,Gateway,Single Node). ABH and ABR drivers can be downloaded from site below.
Also the OPC driver with some OPC server would be a good choice.
http://www.gefanucautomation.com/products/fixiodrivers/showdriverpaths.asp?path=%2FDrive000%2FHardw000%2FAllen000%2FIntel000
http://www.gefanucautomation.com/products/fixiodrivers/showdrivers.asp?objid=613
Hello, i would like to control a pneumatic valve based on conductivity of the medium in the pipe. I want to receive OPEN and CLOSE feedback as...
1,403
Hello everybody. I am a new poster to this forum, but have been using PLC.net to help me through issues for a long time now. So I have to say...
3,489
Hello, Its my first time using a PLC and I'm trying to create a program for solenoid valves that will control hydrogen gas flow through a series...
43
7,535
Here's my situation, I have a press where the primary safety devices are E-Stops and Light Curtains. All of which are hard-wired according to all...
3,724
Good evening, I'm applying for a job and the company is using Direct Logic PLC 205 to control and monitor machinery. They are using a Industrial...
2,965
