AssUMing that your valves open on energization and close on de-energization, here is Revision 3 using 1 timer. With the complicated timing scheme, you might as well use 1 timer and comparison instructions to bracket each time period.
This program is a candidate for the Automation Direct DRUM sequencer instruction with a time base (see the CLICK Help file). If you want to learn something, that would be a good method to try. Most likely after you use DRUM for awhile, you will decide that it is easier to make timing changes with the plain old timer version.
