Ab ControlLogix file
I thought you could use the import function under studio to open a file from version 20? did this work or no?
Likely he needs to work with the file, change programming etc. Import will do a whole lot more to the file. The controller may not even be capable of running V30.
If you try to open a project for a version you do not have, then you should see an option to convert the project to a version you do have. You don't need to perform an import. It will convert it for you.
But, if you convert a project from version 20 to say, version 32, then it will no longer be compatible with your version 20 controller. It does save a copy of the old file though so if you forgot to make a copy you do have a way to recover.
So ideally you want to add version 20 software to your PC. It will install and run fine along with your existing version(s). They are meant to be installed alongside each other. As ASF mentioned earlier, the software will inspect the version whenever you open a file, and it will open the proper version of RSLogix/Studio 5000. My virtual machine has version 13 - 33 installed together.
OG
I now have V20.05 running along side of V32, designed to do this (called AB to make sure), so no issue. Thanks for the help...
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
1,996
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,553
Hi, is there a way to read a CSV or XML file into the Studio5000? Early phase of project and trying to avoid using Omron to read XML file (there...
3,194
Forgot my dongle at work, would someone please save as a l5k file for me. Have to do some importing of tags for rsview 32. Thanks.
1,479
Overview I have 3 registers, 32 bits each, to log to a CSV file. And I'd like 'THE PROGRAM' to read 4 registers and write the data (first 3) to...
17
21,277
