AB Dataliner DL30
punder30
May 2003
16
:confused: I am trying to edit a old Allen Bradley :rolleyes: Dataliner DL30. I have the manual and software and can play around in there. However, I do not have a cable or "dummy terminal" to communicate with it. This is probally "old school" so excuse my ignorance on this matter. :rolleyes:
The manual said I can use a RS232 cable that converts (inside the cable to TTL logic) and to a RJ connector of somesort on the other side of cable if I use a terminal other than a "dummy terminal." ... :( maybe a PC???
Anyhow, I'm lost on this matter and any help...any help at all would be greatly appreciated.
Thanks in advance!! :)
From what I can remember you are correct that the cable has a circuit to convert to ttl level . I went through this relativly recently fortunatly they were able to find the programming keypad (tucked away on a long forgotten shelf) so I could make my changes. I will try to look at the keyboard to see how it is set up with circuitry. If I recall the plug is an rj-11 (phone jack) 6 cond, but I will take a look.
You said you have the software so a pc can be used ,however I have not used the software to make changes. I believe you have to have a copy of the program because it cannot be uploaded from the dl30.
Drewcrew6
Hello Everyone. I have a Dataliner DL50 that I am using for a project here at work. As of now I have two DL40's. One on each line. Those are...
1,534
I have 2 Dataliner DL50 displays (2706-F11J) that are driven from an AB 5/03 PLC. Its old school but works very well for being in service for ~15...
2,770
I have a Dataliner 30 that someone decided to get wet and fried it. As far as I can tell the DL30 gets its info from a TTL output card from PLC5...
1,488
I have read the User and Programming Manual, and Im still not able to figure a few things out. Is it possible to upload messages from a DL20 and...
1,552
Greetings to all ! Does anyone know where I might get my hands on Development DOS based software for an Allen Bradley Dataliner 40 ?
6,258
