AB Ethernet - Pass commands between PLCs? Logix500
TimD
Aug 2007
New Hampshire
235
Hello,
I have two ML1400 PLCs which share some I/O duty (i.e. I am using outputs on both PLCS to drive a bank of solenoid valves (1-6 on PLC 1 and 7-10 on PLC2).
I know how to use the MSG block R/W, but was hoping I could just address PLC2 directly in PLC1, making PLC1 contain the "main" program, so when I write an output in PLC1's program, it can drive that output on PLC2.
If I can't discretely address, then I'll have to bulk-transfer address/values via the MSG function, otherwise, I'd have to write two portions of the code to both PLCs, which seems like a mess to me.
Thanks for your help.
Tim
MicroLogix controllers aren't made to run remote I/O like ControlLogix are. Unless there is no other way, I never recommend using MSG instruction logic to perform I/O control functions.
The MicroLogix 1400 supports up to seven 1762-family I/O modules. Are you already maxed out ?
Till now we used SLC500 on our machines. I was able to setup devicenet by using pass through ethernet - devicenet, on SLC processors. I like to...
3,417
178
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
96
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
306
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
467
