AB Hydraulic Configuration Software for 1746 QS.BD1 card
R_Serif
Aug 2009
Williamsville, NY
Any sugestions for downloading the AB Hydraulic Configuration Software for 1746 QS.BD1* card?
I used the following link:
http://literature.rockwellautomation.com/idc/groups/literature/documents/qs/1746-qs003_-en-p.pdf
"Path to the Allen-Bradley website: http://www.ab.com
extension to manual: /manuals (Application Systems Library, publication 1746-6.19)
extension to Hydraulic Configurator and ladder logic: /mem/appsys/prodinfo/applac/appla/qssw/index.html
Download manual, Hydraulic Configurator, and ladder logic to separate subdirectories in your hard drive.
and IT DOESN'T WORK !
Thank you !
Hydraulic Configuration software 1.43
Thank you James/Peter !
I do have an EConnect suport contract with Rockwell Automation. The "Submit a question" page is locked/malfunctioning, and they can't even locate my contract. I keep sending emails since yesterday. I was told that the Hydraulic Configuration software is free and that was the reason for posting on PLCS.net.
From the old archives.
http://www.deltamotion.com/peter/QsCfg/
Wow! December 1997
I would install the QsCfg.exe in the 1.43 directory if you just want to get the job done. The later versions were never released. There were no new features added after 1.43. The newer versions were generated just because there were changes in related products or we had to recompile with newer versions of MS C++.
This code was developed on Windows 95/98 which is not even supported anymore. Let me know if it works on Windoze 7 if that is what you are using.
AB Hydraulic Configuration Software Download
Thank you Peter !
I apreciatte so much your help. It is installed on my laptop right now.
I also thank PLCS. net for providing this network. It really works...even better than Rockwell Automation TechSupport, which still didn't respond to my request yet.
Hello everyone, I'm reaching out for assistance regarding a project I'm currently working on. Specifically, it involves a hydraulic system with...
421
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,966
Hi, I am about to start a project controlling a hydraulic ram using a Siemens S7-1200 controller. It will need to be quite steady control, by...
768
Good Evening Everyone, I am attempting to monitor the level of hydraulic fluid in a tank. The tank is 50 gallons. For insurance purposes we need...
16
4,204
Hi I have an electro hydraulic valve with coil resistance 22 ohms that takes as +/-12V DC input with 40Hz dither superimposed. The valve controls...
2,545
