AB Inview Comms
GertThePLCGuy
May 2007
New Brunswick
20
I have a few questions with regards to a 2706-P42 Inview station that i'm hoping somebody could help me with!
- When using point to point do I leave the Micro communication channel configured as DF1?
- What do I configure the Inview Communication port to match up with Micro DF1 ? RS232….
- With regards to the cable am I going to only use the RXD and TXD wire termination on the Inview terminals, in the PM02 cable?
- I see in the manual for the Inview station in the example code it refers to using a String File, I’m only familiar with using an Integer File for Inview messages so can I still do it with integer files in the Micro Logix family of processors? I only want to dispaly variable data!
never worked on one but from what I read in the manual for point to point you will need to use the channel 0 which is a df1 protocol (rs 232) and the only data it accepts is ascii although the manual did mention the channel 1 can be used on micrologix
I have an InView P22R with the external 2706-PDH485P comm module. The module requires external +24VDC to operate. It is configured (programmed)...
1,580
Hello Friends We have a Inview 2706-P72CN2, it had been working OK. Showing OK Parts, NOK Parts and Goal Parts. Suddenly, it has stopped working...
337
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
934
Currently I'm programming a Controls Spectrum InView P42C-SC using a ControlLogix. The display has an ethernet communications module attached to...
1,360
I have a customer that sent me the email below, I have been trying to find an answers in the manuals but cant find much to help He is using a...
4,421
