mike J
I have an AB kinetix 6000 system that every so often starts 'vibrating'. It takes out the entire rack. I think I have it narrowed down to a partictular motor/drive, but after changing every component, (drive, motor, FB cable, backplane, filter), the problem re-occurs. Usually, a power cycle clears the problem, but not always.
Tuning the suspect motor/drive combo doesn't permanently fix the issue either, as it re-occurs. Does anyone have suggestions?
