Kinetix drive vibration
benj
Oct 2015
Missouri
I have a simple machine with an Allen Bradley Kinetix servo motor model TLY-A230T-HJ62AN. It's being run by a Compact Logix PLC. The purpose is to rotate a vertically positioned ball screw used to raise and lower a test device at speeds and distances input through an HMI. The total travel is about 40 inches and the top speed is 10 inches a min.
My problem is that occasionally, it will start making a loud buzzing/popping noise from inside the servo, but only while traveling in the downward direction. However, if it starts making the noise. the noise will continue throughout a programmed pause. During the pause the motor shaft will be twitching back and forth. If, during a pause with buzzing, you grab the shaft by hand and attempt to rotate it, it seems like the motor finds the correct position and the buzzing/twitching stops. I want to try an Auto Tune, but when I'm in Run mode, the Auto Tune start is grayed out, if I'm in Program mode I get an error that the drive isn't ready.
Any advice on how to start the Auto tune or if I should try something else first?
Hi, Again, a topic about Kinetix 5100 servo drives. The controller is L33ER. The servo drive are 2198-E1020-ERS with a TLP-115-200-DJMC2A. There...
556
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
889
Kindly, we have one Kinetix drive in stock, sitting since three years. Can we directly install and run it on the machine? Or it needs some...
2,597
Hi All, I have a large servo indexer chassis that uses an AB servo and Kinetix 5500 drive. It seems logical to me to try to limit the amount of...
2,118
I have a customer with a Kinetix 350 servo drive. They were having issues with the old servo motor so they replaced the servo motor with a new...
18
8,379
