AB Licencing scheme
cjd1965
Apr 2007
UK
1,659
The plant I am currently working at is about to get a new machine, with an AB control logix PLC.
At present we have no software, but it is to be 'included' in the machine purchase.
It is typical here that the programming software would be installed on the machine HMI to allow maintenance etc to monitor for fault finding.
Is the licence a floating network type,hardware dongle or key disk type
The intention is to have at least 2 keys to allow for offline familiarisation training away from the machine
Cheers
They use keys, but I think that you can install on different computers and move the activation between whichever computer you currently want to use. The default shortcut for moving activation is:
"C:\Program Files\Rockwell Software\RSUtil\EvMoveW.exe"
Hope this helps..You'll enjoy Control Logix, eventually.
Here are some FAQ about Factory Talk that might help. But the best way is to contact your local AB rep.
I purchased RSlogix5000 ver 16 6 months ago and was required to use the internet to activate it. This would not allow me to transfer the activation between my work computer and laptop for uploading/troubleshooting. I contacted my AB rep and they shipped a 'master disk' with the activation on it so I could use EMove to transfer between the 2 computers.
AB Keys
They also sell a usb dongle (about $100). Instead of having the software attach to a network card you can have it attach to this special usb dongle, which would make it floating.
Thanks for the replies. The dongle sounds ideal. I can put it into the engineering stores and it can be booked out and returned as needed and used on multiple laptops
Cheers
Good Day fellow PLC practitioners! I'm looking for some advice regarding a Siemens WinCC Licencing issue. The system in question was installed...
2,345
Hi Everyone , If anybody have any Idea between Intouch license detection & Ethernet port relation ? I am working with an Intouch panel PC...
1,915
Hi all. How do you usually handle windows server licencing? If you have four shifts, you want to buy device CALs, but you need to buy a device CAL...
2,536
Hi Guys, I have converted a Windows XP Pro to a virtual machine for to be used on VMware. I have got those files and can open and start that...
3,829
Hello All Could we get some expertise on flow control ? -Using a PID loop in Productivity 2000 with an analog output, How can we convert...
19
1,611
