AB Logix L62 major fault - Question on CF Card
harryting
May 2002
Puget Sound
2,595
One of the L62 faulted last week. First time I seen one of this in my many years of working with ControlLogix. Rockwell seems to take this seriously and asked for a bunch of information and one of the ask is the content of the SD or CF card.
So, typically, we don't have memory card in our contrologix PLCs and I never felt I needed them. Back in the SLC days I actually tend to remove the EEPROM since people tend to forget about them and older program would get loaded after a power cycle. I know one can use the card for data log but what else if the card used for? I guess fault info is one of those so it would be good have one a SD or CF card installed? What CF card would be compatible beside one from AB?
The fault is Type 01 Power-up Fault, Code 60-Non-recoverable Fault.
Hi everyone! Hope you all are doing great! We have a really strange issue with comms between Wonderware and a controllogix L62, we use an...
1,709
Good Morning , We had our 2nd episode in 4 weeks with a 1756-L62 processor causing a backplane communication issue , that caused us to...
2,537
Hi All, Fairly new to PLCs and in particular communications between processors. I'll explain the problem best as I can. I have a new water...
2,077
Good Morning , I received a used 1756-L62 / A CPU , from a vendor that was using it for a trainer. I tried to download a program that is...
1,477
How to Interface the Printer with Controllogix L62 via a AB Generic Ethernet Module Hai All, I Need to interface a Generic Printer with the...
5,646
