AB Micrologix FW
Tom.V
Sep 2013
Pennsylvania
Does anyone know where I can get an older firmware for a Micrologix 1100 (processor 1763-L16BBB)? RA website only has back to ver 10 and I need ver 5 or prior.
Thanks in advance!
Tom
In the description of the v.10 FW there is list of the known anomalies of v.5. Probably if you install ControlFlashv10 and chose "show all firmware versions"
You might be able to get it directly from RA Tech Support, but they're going to want a good reason (and maybe a disclaimer, in writing) about why you want to use an obsolete firmware revision.
If you want this because you or your client isn't willing to update your RSLogix 500 software to support the current firmware, the answer is likely to be in the negative. This is especially true because the RSLogix 500 Micro Starter software, which supports the MicroLogix 1100 controllers, is free of charge.
81
126
122
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
160
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
152
