AB mirologix 1500 memory loss
jeepmadmike
Mar 2005
29
I recently had a customer with a micrologix 1500 plc which had lost all memory of the code stored in the unit, luckly i had modified a few parts of the code and had saved it on my laptop. Any ideas why the unit should do this, there had been no lightning or long power down periods?
A dead short across 24+ to 0v can do this as well. Even if it is only momentary. Look for any loose wires or "modifications" that may have been made while system was running.
Marc
hello friends i have installed a system for the wax feed in which i have to control the temperature for this purpose i used pt00 for temperature...
2,278
Does micrologix 1100 support the scp function. In the Instruction help Section it does'nt list the 1100. I've looked in knowledge base and they...
2,124
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
106
129
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
