AB MLX1100 to Redlion G306K Setup help
peh
Jun 2012
usa
I'm having problems getting a MLX1100 to work with a Redlion G306K through Ethernet. All I want to do is put a pushbutton on the screen addressed B3:0/9 that is in my AB program.
The MLX IP is 192.168.0.7
The Redlion G3 IP is 192.168.0.21
All going through a e-net switch.
I can download to the G3 with the usb cable
I am online with the plc. I can ping the HMI and see it also. I can't get them to work together. The green light on the front of the HMI is a slow on and off at the top led indicator lights.
I have attached the crimson 2.0 file.
Thanks for any suggestions.
In the 'data' tab of var1, try changing the 'mapping' to B003:0000 (but leave the 'bit number' as 9).
I get confused with this as well. The HMI reads the register as a word, so you have to point it to the starting bit. Maybe someone can explain this better?... :confused:
-Eric
That worked great!!!!! Thanks for the fast reply and awesome response. I have been racking my brain for days. Now the green communications light went solid green also. Such a small thing that caused tremendous frustration. Thanks again!!
Hello, I have a 1762-IA8 input module, connected to MLX1100. When I force an input "on", should the LED for that input address light, whether it...
1,400
Hello Everybody.. I have a Micrologix 1100 and i would like to connect this PLC to PanelView. I have 2 possibilites PanelViews.. PV 1000 Color (...
1,531
Hello, I usually use MLX1100 with 1763-NC01 cable to connect my RS485 modbus slaves. But now i have RS232 device (modbus slave) and i wonder if i...
1,873
Hi all, We have a MLX1100 that was down today. Every time we began auto cycle, the controller faulted, and restored automatically, but faulted...
1,889
Hey guys, I know theres a way to do this and i may just be looking at it all wrong, but.. i have to figure out what the amount of a mixture...
1,773
