MLX1100 fatal internal software error
yang1216
Jun 2009
BeiJing
84
Hi all,
We have a MLX1100 that was down today. Every time we began auto cycle, the controller faulted, and restored automatically, but faulted again…
I had to repower the controller then found the error code is 0008. The manual says that means fatal internal software error, and it recommend that
• Cycle power on your unit. Then,
re-download your program and
re-initialize any necessary data.
• Start up your system.
• Refer to proper grounding guidelines and
using surge suppressors in your
controller’s User Manual.
• Contact your local Rockwell Automation
representative if the error persists.
I have re-download and restart the controller, but it does not work.
Who can tell me what should I do then, and why the problem happens.
Thanks very much.
Hello, I have a 1762-IA8 input module, connected to MLX1100. When I force an input "on", should the LED for that input address light, whether it...
1,404
Hello Everybody.. I have a Micrologix 1100 and i would like to connect this PLC to PanelView. I have 2 possibilites PanelViews.. PV 1000 Color (...
1,533
Hello, I usually use MLX1100 with 1763-NC01 cable to connect my RS485 modbus slaves. But now i have RS232 device (modbus slave) and i wonder if i...
1,875
Hey guys, I know theres a way to do this and i may just be looking at it all wrong, but.. i have to figure out what the amount of a mixture...
1,775
I'm having problems getting a MLX1100 to work with a Redlion G306K through Ethernet. All I want to do is put a pushbutton on the screen addressed...
1,377
