AB Panel View 550
deand
Jul 2008
s.c.
I am not realy familiar with PLC's but looking for info. on what cable I should BE using to connect my pc directley to the panel view.I have a 1747-uic converter, but what cable do I use to go from the converter to the panel view?
Please provide the complete catalog number of your PanelView.
There is no way to help you until we know the protocol your PV supports.
Your PV has an ethernet port used to connect to your PLC, SLC or what ever brand you have. It also has a RS232 port used to connect a printer or upload/download your PV program. If the RS232 port has not been configured as a printer port, then a staright thru cable between it and your PC/Laptop will work. Use the DF1 driver in RSLinx for this connection. If your laptop does not have a serial port the a USB to serial adapter will work. The best USB to serial adapter is a "Keyspan" brand.
Your 1747-UIC is a USB to DH485 converter, it will not work with your PV.
Also to upload/download using Ethernet you will need to know the IP Address of you PV and will need to change the IP address of your laptop to be on the same network as your PV to communicate over RSLINX
Used the RS232 port with the straight through cable. Worked great! Thanks again for the helpfull advise.
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,437
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,930
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,774
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,050
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,777
