AB PanelView Component - Connection to S7 CPU300
bluremi
Sep 2012
Russian Federation
Hello everyone. I have a problem with connecting PanelView Component C600 with Siemens CPU over Simatic S7 MPI.
I was trying different configurations, different tags syntaxys, but PV don't see tags (2: Data Access Error for Alias xxx, Controler xxx, Adress is xxx, Communication Flag is 0).
My PV tags (Adress):
I126.0
E00126.0
MW20
DB5.DBW0
PV Connection:
S7 MPI
RS422/485 (Hald-Duplex); Baud Rate 19200; Data Bits 8; Stop Bit 1; Parity Odd (was trying None), Local Station Adress 1 (was trying 0, 3, 5), Highest Station Adress 31
CPU_314C-2_DP, Adress 2
CPU-300 Configuration:
MPI Adress 2, Baud Rate 19200, Highest Station Adress 31
For connection I'm using twisted pair with Profibus connector on Siemens side and just "clamps" on PV side, because I don't have 5pin connector that fits here. I guess it's fine, because I've succesfully connected to Micro830 over Modbus with this cable.
Still I can't connect to Siemens CPU. What am I doing wrong?
Welcome to the Site.
The Siemens PLC needs an MPI adaptor between the PLC and The screen
This is common place with siemens
or use the E/Net comms if available
Does anyone have access to a programmer's manual for this? Specifically, I am looking for instructions for the advanced toolbox objects such as...
1,057
I need to get an upload from a 2711C-T4T. I found an old thread http://www.plctalk.net/qanda/showthread.php?p=734222#post734222 on here that...
1,977
I am using a PanelView C1000 as the display and a MicroLogix 1400 as the controller. How do I use a floating point address (i.e F8:0) from the...
1,448
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,583
Hello everyone, I have a 2711C-T4T with firmware 1.80. I am using Connected Components Workbench v10.00 to attempt to download an application to...
2,705
