AB panelView Plus MMI with Siemens S7 314
iknowsomeplc
Apr 2002
USA
199
I want to test AB PanelView Plus with Siemens S7 314 PLC. I have fairly good experience in working with PanelView Plus and RSView Machine Edition for communication to Rockwell PLCs but not worked with a Siemens S7 314 PLC yet.
Anybody did this setup earlier? I guess S7 314 comes with a serial port ( or ethernet also ? ). I know that PanelView Plus support Siemens Serial port drivers and Ethernet drivers using Kepware drivers and now I have Kepserver running in my laptop.
My question is How can I test this configuration without having a Siemens PLC? Is there any software available which will just simulate a siemens PLC serial port in my laptop ? ( Is kepserver doing the same thing ? )
Any ideas???
91
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
57
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
87
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
93
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
138
