Ab plc-5 dh+
eams2010
May 2009
Alex
26
I've a DH+ network connecting more than 20 AB PLC-5. I use the usb to DH+ converter (1784-U2DHP) to monitor and troubleshoot problems. when the DH+ cable is pluged in to the network the Rslinks does not see any of the PLCs on the network however the network for the m/cs is healthy and all m/cs are running. only when I disconnect the network from the PLC that I'm pluged in to, only then the RSlinks can see that one PLC and communicate withno problems. I've changed the lead, PC and I've tried to plug in to another PLC and the result is the same. Can any one help please? Thanks
Perhaps the node # of your RSlinx DH+ converter is the same as an existing node on the network.
What do the status indicators on the USB device tell you? See PDF below.
I would try a very high node address e.g. 63. It can't hurt.
Thank you,
I found the problem. There was short in the wiring of the DH+ network. What makes me confused that the netwotk was healthy and all machines were running and communicating with each other with the present of the short in wiring !!!
Thanks for coming back with your solution. Good to hear all is well now.
The addition of one more node may have tipped the network over the edge.
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
57
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
55
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
82
