AB PLC 5 Rung Comments
bfranklin
Sep 2012
Alberta
125
I added a rung comment then which is associated to an OTE. I moved the comment to a different rung but the yellow "highlite" is still where the comment first was just with no text. How do I get rid of this yellow "highlite"
Nope, checked that. When I replace the OTE with a different address the yellow highlight is gone. I changed the rung comment to be associated with the rung and not the OTE but it didn't not help.
you probably hit the "Enter" key when you typed the comment in.
when you deleted the comment, the "enter" keystroke was left and showed up.
re-edit the comment and delete the keystroke
i just confirmed it on logix 5.
regards,
james
I have often seen statements that arranging rungs so that the condition most likely to make the whole rung TRUE (or FALSE) should be placed to be...
29
8,670
Recently had an issue that I tracked down to a frozen rung of logic. The PLC is an AB PLC5/40E. the rung of logic is simple. (I hope the text...
3,647
Not Sure why I can't implement this piece of PLC-5 logic in a Micrologix 1100 !!!!!! In Micrologix 1100, S:42 = RTC Seconds Register. I...
31
26,311
Hi folks, I am having a little trouble with a rung of code which appears at the bottom of the msg (Sorry, don't know how to paste it in here :(...
3,835
184
